Originally posted by davie
Brakes were very 'trick' using a split system for left and right which uses the old clutch pedal moved next to the brake pedal with a brake master cylinder connected so each brake pedal can be pushed independant or together to either apply brakes to one side or other so power can be diverted from a wheel off ground .
It worked very well
Rick
