Benders??
  • Benders??
    Been looking into pipe benders
    thinking about making a roll cage for the Zook
    anyone done this before?
    and is this up to the job
    not sure what sort of pipe to use yet
    maybe gass pipe??
    [url="http://www.frappr.com/smurfowners"]Surf MAp[/url]
    Those pipe benders look fine to me!! I'd be tempted to use something a little sturdier than gas pipe for a rollcage, tho!!!
    It just does, OK?
      You could have typed that a bit smaller!
      That looks well up to the job. A 12 ton bender would be adequate. Blue band steam pipe complies with MSA regs. You could go heavier guage and use red band seeing as you will have a machine more than capable of bending it.
      It's only a hobby!
        just done a quick search for someone that sells the steam pipes
        no use what so ever
        tube net scared me (tube geeks)
        does anyone know of anyone local?
          YAY!!
          my posts have gone BIGG again
          not sure what i did wrong last time to make it tiny
            There are a couple of places in Luton that I keep forgetting to phone. BSS Pipes 01582 875600 and Pipe Center 01582 404162.
            It's only a hobby!
              "my posts have gone BIGG again"
              It was the gremlins. They are into everything this weekend!
              It's only a hobby!
                machine mart sell the same bender for a little over a hundred pounds ,but you could hire one from your local HSS hire centre ,as already said use red band pipe and that way if the bends you require are tighter than you can pull with the bender then you could always buy weld bends and weld these instead
