35" Tyres.
  • 35" Tyres.
    I was looking at the front o/s wheel arch. I measured from the centre of the hub to where the rust ended and then ran the OSF wheel up the ramp. I worked out that if I were to cut the rust out of the arch and shape the inner arch to suit, 35" tyres would fit, with room to spare for articulation. Virtual lift.
    So, all I need now is an SJ410 gearbox to reduce the gearing for when I put the big beasties on and some wheel spacers to go with my bigger offset wheels.
    And if the ealastic band won't turn the big beasties. I could always shove this in. http://cgi.ebay.co.uk/ws/eBayISAPI.d...MEWA%3AIT&rd=1
    I have just thought of a slight problem. What to do with the rear wheels? Bobtail it!!
    It's only a hobby!
    try here phil http://stores.ebay.co.uk/SJ-UK_W0QQc...QQftidZ2QQtZkm
      Richard
      I don't even bother to look on that guys site. That huge font just gets on my wick. He would get a lot more looks if you didn't have to scroll up/down/left/right, just to read about what is on offer.
      Whooops! It is the other twit, not him, that uses huge fonts.
      It's only a hobby!
        i am off to a meet on sunday so i will find out if anyone has got a 410 g/box if you want
          410 TRANSFER box . not gearbox is wot you need . Known as the 'Rock Lobster' transfer box as with the 413 gearbox will give good low gearing . 410 gearbox will not fit a 413 .
          410 transfer box will have the handbrake on it as opposed to the 413 which has the handbrake on the rear shoes . I think you can loose the handbrake off the back and change the propshaft flange to fit the 413 one on .
            will ask for a 410 trasfer box if you want phil lol
              I meant transfer box. My brain is addled from trying to ignore the ear-bashing from the other room.
              It's only a hobby!
                we got a 413 with a 410 transfer box, but the engine needs some bits on.... talking of which anyone got a bottom rad hose or know someone who does?
                If not ill call the parts people.
                BTW goes up anything we just need more grip!
                Tim
                  hi DD do you want just the rubber hose or the whole thing which goes from the rad back to the block
                    just the rubbery bit [hopefull]
                    Tim
                      i have got a spare on my old suki you are welcome to that if you want it.it wasnt leaking or anything after i put a new rad in so it should be ok
