Update:
My 11-day vacation officially started today.
Not a vacation of travelling, seeing different places, getting embroiled in diverse cultures, taking the wife and children on a road trip.
A vacation of delving into the innards of my Toyota truck.
I spent the day in the bodyshop. The cabin is all primered, the front fender flares have been trial fitted, though not with the stock Toyota plastic clips. I opted to use M8 bolts and nuts. Fit is perfect, with the edge of the flares resting snugly against the fenders. I have not fitted the rubber gaskets, those will go on after paint.
As the EX Single Cabin models were designed strictly as Workmate Utes, they left the factory pretty basic. To my knowledge, fender flares were not an option on UK SC's. There's always the glass fibre replica option, a route I did take initially, until I offered them up to my truck, and found they would take hours, if not days to get anywhere close to fitting.
I purchased genuine Toyota Hilux Double Cabin flares in the end. I was going to fit the rears as they come - 2 separate pieces. Today, I ended up bonding them together to make single flares each rear, and additional security in the form of M8 bolts, nuts and washers. Three bolts per side.
The join will be scored with 80 grit paper, then a layer of glass fibre added. Final layer will be a thinner layer of Bondo. They will then be trial fitted to the bed. The fuel filler flap will be modified to clear the flare on that side.
I took some pictures today, tomorrow hopefully there should be more progress. And more pictures.
