Hi
Our 2nd Gen has got a 4" Full Suspension Lift Kit (Not Body Lift), It's the one that LA Supertrux did years ok. It was fitted by the previous owner so I don't know exactly what springs are on their.
I believe they are ProComp +4" Rear Coil Springs (part number 57490) with a set of ProComp ES3000 Shocks.
The back end is sagging and I want to replace the springs for slightly harder ones as we carry a stack of weight.
Any suggestions?
Would the HDJ80 uprated springs from Roughtrax offer enough height to loose the sag…?
http://www.roughtrax4x4.com/?doc=16&cid=1148&vid=1803
I think this is the spec of the springs that are on there…
http://autoplicity.com/products/2814..._set_of_2.aspx
Any suggestions?
