decided to cut off the large overhang of the surf as i keep catching it when off roading and also to reduce a little weight as the back always seems to droop
1st off cut the roof off
next cut the back off neat ready to be welded back on
pic with back cut off
profile of the body steel
profile of the strengthened roof steel
pic of location of back body mount and chassis ready to be moved to new poistion
position of cut line on the roof just past the thickening
body mount cut and welding in new postion 300mm further in
300mm cut off and ready for welding
now welded back on looking OK. needs tarting up but that will be next weekend!
but the amount the back lifts up once all that weight is off is amazing! i will be putting some back when i fit a rear winch bumper.
! but it should work out!
and stick it on the bonnet?
