lifts and the like
  • lifts and the like
    soooooo, i have a set of what i suspect is lift springs, now im asuming i can fit them and wind the front up with little issues about 2 inches. is this rite? cheers folks
    simple answer
    yes
      I understand fitting bigger rear springs but how do you "wind" the front up?
        Tell it you've slept with it's sister!
          If your truck has torsion bar suspension you can increase the preload on the torsion bar.
          Have a look here http://www.4x4wire.com/toyota/tech/torsion_bars/
          Eat.Sleep.Surf.Repeat.
