I have been looking at this stuff: http://www.ebay.co.uk/itm/Aluminium-...#ht_1574wt_648
I was hoping to bolt it to the bash plate; manly for cosmetics but it should strengthen it up slightly, It needs it I have already bashed the hell out of it.
I was also going to cut the tow bar arm off and use some of that to trim the bar.
What stops it from rusting? Is it the poly coating referred to in the advert?
Also Is it going to reduce cooling as the standard bash plate has holes all over it?
it's alloy!
gone to somewhat extreme lenghts to help cool mine, i believe the 3lt dosen't have a back up fan that cuts in on a temp sensor but you could always get an electric fan and a cheapo thermo switch, or just a flick switch in the cab to switch it on when your towing or going up hills etc, easy to wire, if you need any help with that give me a call, all ya'd need is the fan, some 30amp cable for the fan main runs, some thinner cable for the low current lines, a 30amp relay and a switch, thermo switch is a little more involved but not too bad,
