hay peeps goin on the mod side to keep me busy what size and thicknes steel in tube do u recon to use ? i was thinkin 2.1/2" at 3mm thick for sliders and rear bump protector or 2 heavy n thick?
sliders home made
You can get 50mm x 3.2mm easily enough and it's perfect for sliders.Originally posted by tatts View Posthay peeps goin on the mod side to keep me busy what size and thicknes steel in tube do u recon to use ? i was thinkin 2.1/2" at 3mm thick for sliders and rear bump protector or 2 heavy n thick?
Good luck mate, any questions/problems give me a shout.Brian
I meant 50mm x 3.2mm tube you can get 50mm box also, both work well it just depends on what look you prefer.Originally posted by tatts View Postsound, i can do it out of box but i thought round would b better, got hold of a pipe bender to make the edges n the templates to make the tube spacers
so gon order the steel soon asBrian
