I did this recently to Lexurf VII's transmission sump....
I welded a small square of steel plate to the sump pan, drilled and tapped a 1/8"NPT hole for a temperature sender.
As you can see it's well out of harm's way and is shielded by the bellhousing.
I have a couple of Surf sump pans here that I could do the same for anyone wanting to fit a transmission temp gauge to go with their ATF cooler upgrade. I could do it on an exchange basis where I send you a modified sump pan thats drilled and tapped for a temp sender plus all cleaned up ready to fit to your transmission, and you return your old pan to me. That way your truck will only be out of action for as long as it takes you to scrape off your old gasket goop and re-fit the pan. Just postage costs for silver/blue star members and £10 plus post to everyone else. What you fink?
, I'm not convinced.
