my truck has no rear spear wheel carrier,and its something im wanting to fit,anybody got any info on it? cheers
wheel carrier fitting
There's a brace inside the rear quarter you'll need to cut out of a scrapper, also a brace panel inside the tailgate. Also need to change the rear lights to the type with reversing lights. The lock barrel is different.
A bit of cutting and welding needed to remove a bit of the inner rear wing to fit brace.
I bought all the bits to do it a couple of years ago and ended up not bothering.
Originally posted by wishbone View PostThere's a brace inside the rear quarter you'll need to cut out of a scrapper, also a brace panel inside the tailgate. Also need to change the rear lights to the type with reversing lights. The lock barrel is different.
I bought all the bits to do it a couple of years ago and ended up not bothering.Not going to rest till its broke
