Supercharger
  • Supercharger
    Has anybody supercharged a 2.4td?
    Would there be any point?
    And has anybody tried these electric ones?
    Dubt very much if it would take it mate, but if i was going to do it, i'd use one of the superchargers from a mini cooper 's' used to be loads on ebay witn only delivery miles on them, anywhere from 100-200. i did have one that i was going to fit on my goldwing trike when i was building it, they do need a lot of work to fit on another engine though.
      I was thinking of putting it where the a/c compressor used to be.
      Isn't a supercharger just a turbo charger thats always running? (and powered from a drive belt rather than exhaust gas) so if the Supercharger was always pushing out a constant 11PSI (12 being the max) it would be better
        Here you go mate http://www.superchargersonline.com/content.asp?id=15
          That type of S/C doesn't work like that, you still have to wait for boost pressure to build up in the same way as your existing turbo does now.
          Different to the superchargers that are installed after the throttle body, they create power (boost) from idle upwards.
