Lift Questions.
  • Lift Questions.
    Finaly ready to do my lift
    after the problems ive had with surf this week its off road and time to get bits done few questions though
    fantastic information about the 3 main ways but unsure on best way.
    http://www.hiluxsurf.co.uk/forumdisplay.php?f=18
    the landcruiser idea seems to bring up the surf the highest but seems more expensive then the kits form routhtrax.
    are the kits from routhtrax complete would i need anything else?
    if not what do i actualy need for the landcruiser lift.
    1: landcruiser springs = £55
    2: rear shocks 2" = £37.50 ea = £75
    3: alloy seat for springs = £135
    4: uprated torshion bar = £170 or ball joint spacers?
    sure there is more thats £435 + %20 = £522
    Next body lift = safe at 2" Aloy or Teflon blox?
    3.0L V6 Manual 4-Runner
    .:one::.
    Big Sound System (100 Infinity 6x9's Boxed :: 2 JBL GTO 14" 255w Subs)
    Bull Bars (Slightly Customized)
    .::To Do::.
    Tires MT 33's
    Snorkle
    4" Lift
    Tow Bar
    Wind Deflectors
    Spoiler (Front & Back)
    What is your main reason for fitting the lift parts, looks or articulation?
      because i got a bad habbit of getting stuck in ruts dug out by the big boys so want to get some 33's on
      .:one::.
      .::To Do::.
      Tires MT 33's
      Snorkle
      4" Lift
      Tow Bar
      Wind Deflectors
        Well you don't need the uprated torsion bars unless you're going to be using your truck to jump over things, balljoint spacers (4Crawler) are better and you keep the comfortable ride. You could order the spring seats at the same time to save money.
        Type Xpajun into google for the boylift kit.
        Oh and it's Roughtrax bu the way.
          Arg wat a night just had to run my 9mnth old boy into A&E :'(
          But Perfect
          so all in all a better and cheaper solution with the landcruiser option?
          2" ball joint spacers
          Rear spring seats
          3" springs from landcruiser
          2" shocks from roughtrax
          3" braided brake lines
          2" body lift with bolts
          Anything else to add to my list of bits to order over the next few days?
          also any problems anyone is aware with or does anyone know anything about this
          3.0L V6 4Runners may have problems at 3" with the stock engine air intake, modifications will be needed
          .:one::.
          .::To Do::.
          Tires MT 33's
          Snorkle
          4" Lift
          Tow Bar
          Wind Deflectors
            Don't do a 3" body lift then.
              but 5" is only sure way to clear 33's
              .:one::.
              .::To Do::.
              Tires MT 33's
              Snorkle
              4" Lift
              Tow Bar
              Wind Deflectors
                it means 3" over BODY lift will cause intake issues.
                  Lifted my 4-runner here in sweden 3 weeks ago with a 2" bodylift from xpajun, pretty easy took about 3 hours.
                  Now doing 4-5" inch chassi lift from roughcountry to, with some problems with americans usual sloppy making of parts
                  Had bfg m/t 33" last year with no lift and it was not that far of...
                  I don`t think you need more than 3" inches of lift to clear 33" but that depends alot on the rims...
                  Pics of the 33" on my 4runner.
                  http://www.garaget.org/?car=229031 (The pics with black rims...)
                  4 Runner V6
                  Skyline R32Gtr
                  Honda crf 450
                    sent an email to 4crawler today for parts list i will need figured they could supply the best advice reply i got was usefull some more parts to add to my list.
                    1. bracket for the LSPV brake valve in back
                    2. Panhard drop brkt
                    according to them with 6 inch lift could get 35x12.50's on anyone have views on this?
                    could i get away with 3inch body lift with Steering shaft extended, 3" extended brake lines
                    .:one::.
                    .::To Do::.
                    Tires MT 33's
                    Snorkle
                    4" Lift
                    Tow Bar
                    Wind Deflectors
                      If you are on a budget the above are not needed.
                      Nor are the spring seats.
                      35s will make the gearing a little long IMO you coul fit 2.4 diffs front and rear to regain a bit.
                      Brian
                        Sounds like a plan, recon it would be ok to start with?
                        trying to get the mainground covered then fiddle thro the year.
                        dont want so be spending more then 1000 betwean lift and tyres.
                        ive seen full set of KL71's 35x12.5's for 699
                        .:one::.
                        .::To Do::.
                        Tires MT 33's
                        Snorkle
                        4" Lift
                        Tow Bar
                        Wind Deflectors
                          just ordered 3" Body lift.
                          Working on my brake lines now 3" extended. got to change my back brakes anyway they are sitting on my desk
                          Going to do the 3" lift next week hopefully minimal problems cant be withought the car so if i run into problems will have to undo what ive done and use the car until parts turn up.
                          Going to do 2" BJ Spacers on front with 1" Torshion bar wind up
                          with LC Springs on back with seats.
                          I got the Cad for the Panhard drop there is a good place round here does all that kind of stuff going to see if they can put one together for me.
                          not going to bother with the Radiator drop as ive had to fit electric fan anyway. going to find a silicon pipe for radiator with Sensor fitting in just ordered Heat sensore off a calibra. hopefully matt will get me some CV boots on sunday and truck will start to get some Character.
                          .:one::.
                          .::To Do::.
                          Tires MT 33's
                          Snorkle
                          4" Lift
                          Tow Bar
                          Wind Deflectors
                            Tyres:
                            http://cgi.ebay.co.uk/5-X-35-12-50R1...item20b7b5358b
                              dosent quiet have the same apeal as the KL71's
                              .:one::.
                              .::To Do::.
                              Tires MT 33's
                              Snorkle
                              4" Lift
                              Tow Bar
                              Wind Deflectors
