Originally posted by dannyboy77
									View Post
		It's basically the same as before, except the pasenger side driveshaft is now connected to the diff.
You can still drive around in 2WD as before then press the button to engage the front propshaft/diff. when on the loose stuff.
Totally up to you if you want to fit the hubs, but they're not really necessary unless you've cranked your torsion bars right up.
