Hay there many thanks to all who have helped me in the past but I’m now trying to change the stock radio in my mk2 surf and am wondering what size radio will fit and how to remove the stock one and fit a new one.
mk 2 radio
A regular head unit will fit takes about 20mins ish to get the dash apart to get it in and put it all back together. You will most likely need an ISO to Toyota adaptor, if it has the FM expander fitted, then remove it as you won't need it on the UK head unit and it'll screw up your stations.
There's a few links to pictures on how to remove the parts of the dash you need to remove to get to the radio.
peace
calBala Mud, best underseal there is, only £30 per application.
www.thecellardwellers.co.uk
If you have a single unit and a hole under that, kinda like a tray then the tray and unit are held in the same brass type bracket this has to come apart to get the old radio out and will hold a double unit/din.
peace
