I got stuck in a snow drift the other day and was very disappointed to find out the hard way that my truck has no diff locks on the axles! I have a 2nd gen 3.0 95 KZN130 SSRX and I understand that some have a limited slip diff at the back but not mine! Bummer.
I've been looking into options to fit an automatic locking diff and have identified three possibilities:
The Aussie Locker
The Lockright by Richmond
and the Detroit Locker
The detroit locker looks waay too expensive (at least from LA Supertrux) and I can't find anyone in the UK that sells the other two. Does anyone know the correct model of the other two for my truck and where I might get them? Also which is best?
Next problem - how easy to fit? I haven't a clue mechanically? Many thanks for all your help
The Aussie Locker
so i pulled it the next day and re-installed taking 0.1mm off each thrust washer, and, which i think may have been the root cause, cleaned the grease off the pins they tell you to use in the assembly docs.
