35mm spacers
  • 35mm spacers
    Hi folks, has anybody fitted the LA SUPERTRUX 35mm wheel spacers and if so any comments on them or wheel spacers in general.
    cheers
    i've got 32mm spacers on my truck and they are ok.Just make sure you get the solid type spacers and ones without the nut extensions as they are c rap and dangerous.Make sure you get the ones that fix to the hubs and seperate studs for the wheels to fix to
      They are very good, they may exaggerate any wear in steering parts, but you'll will have noticed it soon anyway so best you find out earlier.
      Don't overtorque the nuts, breaking studs is the only thing people do alot (not on the wheel spacers, the truck ones) when fitting them.
        The standard wheel nut Torque should be OK for them though?
          yeah, thats what I do them at.
          its amazing how soft the orginal studs are, lots of times I've had bolts that are really jammed on and hard to remove, then when you do them up again they shear as you're finishing doing them up cos they've stretched.
            Aye, amateurs eh? lol
              Thnx to all your replies...just what I wanted to hear.
