Guys and girls,My hilux 2.4td surf main purpose in life is to tow my track car, after that its a general workhorse getting me around for work(electrician) it pretty much never see's off road
so thats the cars life story, now mine has suffered saggy arse syndrome for a while and now the rear is totally buggered and wallowy,so am in need of change.
I dont want to go any higher with lifts etc(a little is fine) and wanna have suspension hardness no less harder than what the standard hard setting is on the switch so what can you all recomend?-bearing in mind i would rather set it up for towing rather than offroading,
And do i need to change the front to?im guessing as im changing from standard to aftermarket i do
Or shall i just get standard again?
cheers rob
cheers rob
