maximum tyre size
  • maximum tyre size
    hi
    can any one let me know the largest size tyres i can fit to my first surf, i have purchased a one and a half inch body lift kit and the model is a 130 3litre turbo, Any more upgrades that can be recomended for weekend off road use and still keep it civilised on road would be appreciated
    rob
    31x10.5x15 is the largest tyre you can fit on that lift
      tyre size requirements
      hi
      thanks for reply, can anyone let me know what other lift modifications i would have to do other than the 1.5" body lift to enable me to fit 32x11.50x15 kumho kl71's and if they fit on my standard rims that currently have 32x10.50
      regards
      rob
        i would go for a 2" body lift and see what the tyres are like then.You should be ok to fit the other tyres on those rims
          I have driven 33x10.50R15 tyres (on original 7x15 et8 alloys) only without any modifications. No rubbing thou.
          Check this:
          http://www.brian894x4.com/33INCHTIRES.html
          I installed SDORI 2" ball joint spacers and 2" spacers for rear springs. This is with them and 33x10.50":
