Es 3000 Part Number
  • Es 3000 Part Number
    Hi folks, does anyone know the part number for the Pro Comp ES 3000 front shock absorber which is 2" longer. I think it starts with 31 and does anybody know where the hell to get them from nowadays???
    pro comp sole distributor in UK is now
    http://www.bearmach.com/
    You would be better getting +3" if you are going off road.
    I would alsp buy es9000, these are also a better choice if you are using LC springs.
    Brian
      Are you are still going for wasting money on uprated Tor Bars?
      If so, I would buy es9000. These are also a better choice if you are using LC springs
      Hi Yoshie, to put you in the picture m8 I just bought Rancho 5ooo +3" to match the ones I just fitted to the rear and I dont think they are the right ones, the bolt dosent go through the metal insert that they supplied me so I had to get 2 new ones that did, that was no problem though. Being the impatient sod that I am I decided to go ahaead and fit them before fitting my 2" bj spacers...still waiting on them from Outrageous..hint hint Neil! Anyway I have no downward travel in the shox at all and they are solid, is this how they should be until the spacers are fitted..really getting p****d off with the whole set up.
        If you've tweaked the torsion bars too high they'll sit on the bumpstops (top wishbone) Just back them off till you get your spacers..
          No mate sounds like it's the wrong shock on the front.
          Where in Scotland are you mate?
          Brian
            I'm just on the outskirts of Kirkcaldy m8.
              Which side?
                Which side?
                I'm in Cluny, just down from Chapel Level area of Kirkcaldy.
                  I know Cluny. Yoshie and I are in Denny(ish), near Falkirk.
                    If you want to come down one weekend I will have a look at your set up, I have lifted a few of these things over the years.
                    Brian
                      Mine will need done again sometime.
                        Aye your good, maybe you should get your arse up here and fix this stereo and fit my cb then
                        Brian
                          That would be fantastic m8, let me know when your free and we can make some arrangements...hopefully be getting my spacers this week and my new tyres...oh before I go, will 33x 12.50x15 fit on a standard surf alloy?? thanks again for your help!
                            Oh aye, forgot about them. You off next weekend?
                              Yes
                              Brian
