different tyres
  • different tyres
    Hi there, I'm in the middle of doing an lc spring lift which should hopefully give me 3"of extra height at the rear and I'm just going to wind up the torsion bars to give me some extra at the front. The question is has anyone tried putting on 32x 11.50x 15 tyres and did they fit... and would these tyres fit on ordinary steel wheels 7x15. My brains on overload with all the different tyre sizes and everythting. All your experiences would be of great benifit to me...thanks all!
    Den
    Should fit ok, i think the "boyo or pops" fitted 33"'s on 7" rims with no probs as to the front lift i dunno if you have no body lift and are just cranking up the bars i'm not sure if the 32's will foul or not, might just be ok as i'm sure 31's will work ok with no fouling on a non lifted standard truck,
    RodLeach's the boy you need fo tyre/rim info
      Thanks popeye for your prompt reply but ive been thinking it over and have decided to go the full hog and fit bj spacers and a body lift and fit 33's, will just take longer to do and and obviously more cash but will be worth it in the end....I hope!!
        if you look on the home page of this site on the right hand side mid way down there is a tyre size index (exel format) should be able to give to better idea on sizes of tyres
        as far as fitting 32" on the front with no form of lift which i think is what your saying?? the would fit but i dont think you could get turning full lock??
