can i get away with just changing the rear springs for +2" or do i need to do anything else?
+2" rear springs ????
Pardon me for saying but did'nt i cover all this in the write up on your last post?
apart from that, all of wot he said applys, you could just change the springs, all depends what you do with the truck, if it's just for on the road, you'll get away with the old shocks but it'll top out on bumps etc, (bang) you'd have to see how "stretched" the break hose is when you've dont the lift, spacer the whole load sensor bit down a bit if it looks too tight, and if you dont change or alter the panard rod it'll pull the body out of line a bit,
is it a matter of finance's?
i want to do it properly but finances are spread out so a little here and there is what i was hopind to do until i can get it all done.Originally posted by POPEYE View PostPardon me for saying but did'nt i cover all this in the write up on your last post?
Fair enough mate, in that case you can just do the spring change without any major issues, just remember when you undo and drop the axel to fit em also undo the break load sensor (three bolts) and unclip the pipe from above it so you dont muller it, then just see wot it's like with the new springs and with the axel at it's lowest (truck jacked up and axel hanging) old shocks will do ya for now (my old ones are still on and been through mot etc been on for almost six months, just an annoying bang on speed bumps etc)
panard rod will be the only prob as i can see, without shelling out 80-100 quid for an adjustable one i'd cut and weld, do you have or know someone who has a welder arc or mig? be happy to do it for you if you aint too far away
Your welcome, getting the bolts out the radus arms is a bit fiddley, question of jacking the axel and tapping em out with a drift, trial and error, see how everthing looks when the new springs are in, ARB links should be easy to drop, longer links or make up a bracket, (or dump the whole thing, like i have)
new springs arrived today and they are exacly the same as my original toyota ones, not happy!Originally posted by POPEYE View PostYour welcome, getting the bolts out the radus arms is a bit fiddley, question of jacking the axel and tapping em out with a drift, trial and error, see how everthing looks when the new springs are in, ARB links should be easy to drop, longer links or make up a bracket, (or dump the whole thing, like i have)
yes, part # su005, fitted and they're the same gap as before, measured 8 1/4" before and after.
they are thicker than the originals but both same height too and ad states they should be different.
i am awiting a reponse from barry @ roughtrax.
Sounds like you got uprated (stiffer) springs, thats why i went for the LC ones, as i'd heard dissapointing results before regarding increased lift, Barrys a reasonable/helpfull bloke tho, best to give him a phone call, how much were the springs btw?Too young to die and too old to give a toss
£88 give or take a few pence, spoke to barry, top man, i have got one wrong spring and he is sorting it asap.
i am very impressed with the service i have to say. they are very good at sorting this out and he also gave a lot of extra tips and advice regarding my projects.
well worth a visit and i will def be using again with backup like that.
When I did the same as you, mine definitely had the back sitting a bit higher, even without any changes to the shocks, etc. I could tell because I had to wind the caravan jockey wheel higher than normal to get the hitch on the hook. After towing for a couple of hundred miles it seems to have settled down a little, but solo the back is still about 1 1/2in higher than before.Mike G
I did mine with +2" springs and got a hell of a lift! The arse sag on mine was so back I got 4", +"2 to standard height and +2" lift!
I didn't change anything else on the back end and I even changed the springs without taking anything but one wheel at a time off off, but I did have to use 2 pairs of spring compressors though!
The old springs were so bad my brother was compressing them by hand on the floor but the new ones didn't shift at all, like I said, the old ones were properly knackered!
Ray.I've got a plan and it's as hot as my pants!
