Ball joint spacers HELP
  • Ball joint spacers HELP
    I have just fitted the ball joint spacers on my surf but now the wheels are leaning out at the top , is there a way of ajusting the angle back to normal ?
    Thanks Mark.
    you're either talking about toe or camber
    yes they can be adjusted,but probably best left to professionals
    私のホバークラフト は鰻が一杯です。
      Yep, you need to find a proper wheel alignment centre to set it all up properly. Krap Fit and the like wont be able to do it, even if they say they can. As a guide you will be looking at around £100 to do it.
      Ebay search item 230357761354 !
        I paid £70 to have the front end of mine aligned - franchise called 'steertrak'. They mainly do big commercials, but were happy to do mine. Had it done about a year ago, just before I put new BFG ATs on. No noteable wear on the front tyres up to now, whereas it used to eat the fronts before then.
