What thickness bar for rock sliders ?
2mm will be ok,but it will be a bit of a git to weld without burn through.and if you do hit a tree or rock its liable to bend or break,you would be much better off going for 40x40x3mm or 50x50x3mm box section it might weigh a bit more but at least it wont bend or break under a sudden impact.apache yours are 3mm thick.
Hi Apache,Originally posted by Apache View PostFrom memory, mine are 50mm, and look about 2mm. They work!
BTW, dont use bar, they'll be too heavy
I want to do something like the pic below. They are around 3mm thick from the info on this site
If I can make them from 2mm and still be strong enough then the weight saving is a bonus.
Thanks.
Rob.
Leave a comment:
Originally posted by Bibs View PostI have aquired some stainless steel box - 50mm an about 2mm. We are looking to make them in to sliders - what do you mean by bar?
Don't use stainless viv, it will look rubbish!
much better suited to my grey truck so send it north.
Leave a comment:
Leave a comment:
Am looking at making some sliders out of square tube. Probably 40mm x 40mm. Comes in different thicknesses - what do they need to be ? 3mm ? 4mm?
Have searched but didn't find the answer.
Thanks,
Rob.Tags: None
so will fit nicely with my crappy paint
Leave a comment:
