well then I will finally fit my diy snorkel later...
Seen as I wanted to save my money for a lift I decided to make a cheap alternative to a snorkel,
as some of u know I bought this:
Due to the bulge on the bottom it would not be a snug fit.
Also welding it straight to the bonnet did not seem like a brilliant idea, because I would probably blow a hole.
Also I would burn the paint off etc...
so the bottom come off and put a square plate on with four bolt holes.
I will cut a nice round hole in a minute and 4 little ones for the bolts and then just bolt it straight on with 4 stainless bolts and double nuts on the bottom..
Bit of silicon in between that should do the trick...
This is what it looks like now..
Its the 2nd gen tractor thing I suppose
Is it to late to adjust the angle so its upright?
