For fitting LC HDJ80 springs for off road use, i've been told to get +3" rear shocks.
I spoke to Pro Comp who said that they don't do a +3" ES9000 but do +2" and +4". The bloke then said they do 'something in between' at 24.8, 25.7, 26, and 27 inches fully extended? He didn't seem keen to offer any more explanation apart from saying i'd need to stick the springs in and measure the distance or something which sounded a bit of a mission.
I'm guessing that i'll be wanting the 24.8's (fully extended length)? Or will the +4"s be ok?
And is it necessary to do the panhard rod mod and the ARB drop brackets? If so then why is that? Is it advisable to go off roading without doing so? I know this is a lot of questions but i keep getting all sorts off different advice on which shocks to get.
Are pro comp always as gash on delivery times as people say they are?
Thanks.
Thanks.
