Fitted the scoop today. Here's some photos so far. I'll add to this as the mod progresses.
The Isuzu Trooper scoop underside sowing the mounting points. The rear centre one needed reducing in height. Cut it off, remove 5mm and glue it back - I used araldite.
The template I made for hole drilling. The square drawn on it is the size of the intercooler 'vaned' area. The only area you should expose to airflow to maximise cooling.
Pics of the scoop fitted. Its almost a factory fit! The colour match is slightly off, but I'll get a can of paint and do it before the final fitting.
