ordered some of these, just wanted to know are these fitted to just the upper joints or both?? t.i.a
ball joint spacers
Originally posted by smiffyWhere did you obtain such things???
http://www.4crawler.com/4x4/ForSale/...taOnlyProducts
thats em..Originally posted by BUSHWHACKERCHEERS JOHN................
oh ok m8 stormy we better take yours off again then to do lol ty boyoOriginally posted by The Lovely BoyoThe groove should be placed downwards onto the ball joint. It allows water to leak out of the bottom of the spacer.
If you put it upwards water will collect and start to rot the upper arm.
Some advice please guys
I'm I correct in assuming these give 1.5" of lift once fitted?
Do you have to adjust the tor bars to match?
If I fit 2" lift springs to the rear do they give a full 2" of lift?
If I went for the 2" spacers from the crawler site would they give 2" of real lift
Or are there geometric forces at work that result in a lower over all lift than the sum of the parts fitted.Brian
If you fit the balljoint spacers, there's no need to adjust the torsion bars.
2" lift springs should do just that, raise the truck/suspension 2", but may be firmer.
If the springs you have now are OK, then 2" spring spacers may be a cheaper/easier/softer alternative.
http://www.toyotasurf.asn.au/techsite/suspension.htm
Originally posted by slimthats em..
Did you have to get a quote for delivery??? If so how much for the spacers and delivery.?
My cv's are running at a dodgy angle,dont want to wreck them!!
Cheers.www.scottishmudclub.com for scottish events
