Originally posted by Robmatthews
View Post
no i did'nt finish it, the price of veg oil went so high i lost heart, it was nearly don tho, all that was left was to replace the cheapo switchover valve for a decent one, pipe it and wire it, and sort out the second tank filler,
no you dont need the extra rad, it's just my overheating paranoia,
i'd reccomend a 12v pump from the states, still cheaper than here, i'm running on an old bus 24v pump so it's running half speed, just never got round to replaceing it,
not sure about the in tank pumps tho i dont see why not, it's just the tank i got (110 defender) did'nt have one so was going to fit an in line one
and as i could'nt afford a 12v one i stuck this in after testing it on 12v in a bucket of water, it's prob running at half speed but still seem'd to pump water fairly well and it does move water round the system ok, keep meaning to replace it with a 12v one but aint got round to it yet, their quite expensive being at around £100 + mark, a bit cheaper from the states but your lible to get hammered for import duty i'd guess, so scrapyard or a caravan pump (if they can deal with continious hot water use), check ebay etc, for 12v car electric water pumps, i think some cars have em, not sure,
you been reading that BJ Blaster link aint ya, he did several methods of filtering and his dad i believe owned a wast oil company which helps, plentiful supply on hand!!!, i'm waiting for some filters from these guys---
i can then draw off as i want and stick it straight in the truck or store it in some 20 lt containers, i'll stick a pic up when it's all finished,
have you fitted a second tank gauge so you can see wots in the veggie tank? i got one for a land rover 110 off ebay,
just got sick of useing the five funnel and bog paper method, anyway hats off to ya for your work there, your a man after bj blasters heart
had a defender and helped me out there, the back connections are marked and if i remember one is 12v live (ign) one to the tank sender, and one earth, i can check i think if you need more info, thanks for the offer of help and if i should decide to finish it i'll give you a call, i would really need to junk the "pollak" changeover valve and replace it with the supposeidly much better "prevokil" german one, a bit expensive but the best around i'm told, got the pollok from the US, cheap and it looks it,
