No tippy over device
  • No tippy over device
    If the rain holds off tomorrow, I'm going to fit it - are there any tips on how? And good places to get the light plugged into?
    TIA
    I couldn't be a$$ed with the drilling and bolting bit so I used double sided tape. Worked fine, been on for about 6 months now. (Note - you need to build a mounting surface on the base of the pod first! I glued in some flat plastic pieces with araldite)
    re. the lighting, there is a instrument lights feed in the radio loom. Just get a meter on there and look for the one that goes live when you turn your lights on, and tee into that one. Thats about the closest and easiest feed.
      Nice one - cheers Andy...
        Did you have to take the dash off to do it???
          As I understand it, the wiring is already in place. There is a connector behind the dashboard below where they fit that it just plugs into.
          Paul </Slugsie>
          Immortal.so far!
