light pods
  • light pods
    anyone here fitted any light pods from direct 4x4 i got a set they look great just one problem could do with finding a way of running the wires down out of site without having to drill holes in the roof any ideas guys
    thanks
    mick
    Just drill the hole. It's no biggie. The roof is very thin and there is plenty of space to run cables down the window pillar.
    Check out http://www.hiluxsurf.co.uk/forums/sh...ad.php?t=30226 to see how I did mine.
      light pods
      i know its not hard was just didnt want any rust to form and create a bigger hole suppose itll be ok if i seal it
      thanks
      mick
        Use a decent waterproof gland, the hole will be sealed from the elements then.
        Mine has an o-ring, but I siliconed it too. I've run the car through carwashes since (taking the bar off first) and have had no leakage at all.
          ok will do that
          thanks
          mick
            Might be worth painting some kind of sealer or something on. Ive not had to drill any holes in this truck.... YET!
