Just thought i'd share a pic of my dash now i got the CB and extra accessory sockets installed, and turbo timer relocated.
The whole stereo carrier has been moved forward about 6-8mm by using longer bolts and a couple of nuts between the carrier and the mountings, Same technique used to install the cb into the carrier. Ashtray removed to allow the 4 extra sockets to fit neatly where the ashtray was, and turbo timer moved to it's current position in view of the driver. The switch on the left is for the accessory sockets, which are on a constant supply from the fuse box in the drivers kickpanel now switched by this, and fused back at the fusebox.
What do you lot think?
