fitted my new crystal headlights today and the look a lot better than the original ones
crystal headlights
Where from? are they the roughtrax ones and did you upgrade the wiring? i miss the lights from my old escort but they were the mutts nuts, my surf ones are like a 99p torch with flat batteries.Originally posted by j.hellfitted my new crystal headlights today and the look a lot better than the original ones=========
=SOLD UP!=
Originally posted by j.hellyes they are the roughtrax ones and they are a straight swap no altertations needed not to sure about the beam allignment yet though i did it roughly the same using the garage door
do they actually increse visability as well as look better. my standard lights are $$$$ if i nock down one more sheep people are going to start getting suspitious
they certainly look a lot brighter,than the other candles you were using.im intrested to see if they make a lot of difference in the dark.and to see if the heat from the bulb melts the plastic lens.Originally posted by j.hellfitted my new crystal headlights today and the look a lot better than the original ones
www.overfab.uk
