Body lift, suspension lift.. or both?
  • Body lift, suspension lift.. or both?
    Just been reading on body lifts and suspension lifts.. but which is the best way to go? Can you do both and what would be the advantages?
    So far the 2" body lift from offroadtoys is looking good with the HDJ8 rear springs and 3" ES 3000's (and the kit from Bushwacker)
    Would this work, 5" lift?
    What else would I need to mod, ie brake lines, stearing extension etc?
    Going to have a go at this myself but just need to make sure I have all the right info as if the Surf is off the road my Mrs will want to use the Celica, and thats just not going to happen
    -=I swear to drunk I'm not god=-
    the steering extension happens when you do the bodylift by slacking of the bolts on the steering colomn.You may want to get extended brake lines too as i have done.I have also got a diff spacer kit from Jotto so i can lift the front a fraction higher.you wont get a total of 5" on the front end tho,i am hoping with the diff spacers that i may be able to get about 3" to 4" at a later stage.
    What i have ordered is:- hdj80 springs,2 x +3" shocks for the rear,2 x +2" shocks for the front,A Bushy special kit for the panhard,Diff spacer kit from Jotto and extended braided brake hose x 3
      Excellent.. and thanks for the info. I have just noticed your also a fellow Celica owner, Gen 5 or 6?
        gen 6 but its the wifes.They are a lovely motor and goes like sh1t off a shovel.It's black with gold alloys
          Originally posted by stormforce1067
          It's black.....
          Naturally..........
            Originally posted by TonyN
            Naturally..........
            only the best will do.
              Hi stormforce were did u get ur panhard dropkit from and ur hoses and how much did it cost?
                Hi Fraser i got the brake hoses from Roughtrax and the panhard drop bracket i got from Bushwacker.If you give him a pm and let him know what lift you are going to do then he can make a kit for you
                  the brake hose is kit (2 front and 1 rear)is £36 plus vat and p&p
                  and the panhard kit is £47 inc from Vince
                    thanx stormforce i have already dun a 3" body lift iam goin to put land cruiser springs on the rear and sum diff spacers so i can wind it up a touch es 9000's all round.
                      don't forget some b4 and after pics
