Body Lift Kits
  • Body Lift Kits
    anyone interested in some body lift kits (50mm/2") ? i might get a friend to make some.
    they will be fairly cheap and some £££ will go to the forum.
    Tim
    Possibly, but I need to look at what's involved first and what other expences there are.
    Damian
    http://www.themudlife.co.uk
      if i do it i will try and get everything including drop brackets.
      just an idea -
      Tim
        put me in for that mate what sort of price we looking at cheers
          i would also be very interested, especially if you can get the drop brackets for the rad and bumper in on the deal.
          any idea of a rough figure, or are you still at the planing things out stage?
          keep us posted
          cheers scotty
            hi mate - not sure when but you should be able to get a cheap kit soon enough in a month or so.
            Tim
              great stuff
              is there much of a difference (fitting wise) between 2" and 3" body lift?
              if not could a 3" body lift be made?
              i assume you will be getting one yourself?
              like i said keep in touch cheers scotty
                Yeah, I'd be interested too, if the price is right...
                It just does, OK?
                  i would be interested too
                    Originally posted by scotty
                    great stuff
                    Any more than a 2" body lift and you run into extra problems i.e. steering column and gear levers.
                      thats why I picked a 2" lift - im sure 3" could be done too but might be extra work.
                      ill update this when i know whats happening but the idea being you wont need to fab any parts yourself as you would with most other kits.
                      Tim
                        www.supertrux.com
                          Toyota 4-Runner/Surf Body Lift - Just £265
                          The L.A.Supertrux Body Lift Kit is the only billet aluminium body lift kit that we know of in the world. CNC machined from aircraft quality T6 aluminium, our lift blocks are then hard anodised in an attractive purple finish for lasting good looks. Each kit is custom designed to suit the vehicle application. Because of this the exact contents vary from vehicle to vehicle but a typical kit will include alloy lift blocks, longer mounting bolts, bumper relocation brackets and full fitting instructions. Please note that there are some kits which require steering column modifications.
                          You will be required in the check out process to enter vehicle make and model, this will allow us to provide you with the correct product for you.
                          Fitting service is available at our workshop for only an extra £455.
                          Price Including Shipping: £324.89 (Including: VAT at 17.5%
                          HOW MUCH!!!!!
                            GULP!!!
                            Tim
                              The instructions must cost £200 then!
