my surf has a 4" suspension lift and a 3" body lift will 35" tyres fit?
thanx andy
They should fit OK at least as regards the diameter, widthwise it may be a little different, this will depend on what width the tyres are, which wheels you are using, if you are using spacers etc etc.
You may also wish to consider re-gearing as thats a hell of a lot of tyre to be turning, otherwise you may fine you end up with poor economy and poor performance too
I had about 7" on my pickup and it cleared 35x12.5" OK, 35x16" still rubbed a little though. So like Morr says, depends on wheel offset and tyre width.
