As my Surf failed its test due to the 33" tyres fouling a front wishbone, I figured a set of wheel spacers would do the trick. The 32mm ones from trackstore would push my tyres too far our past the arches, causing a test failure so something slimmer was required.
I went with a set of 1/4" (6mm) ones which I got on eBay from this seller, cheaper than any UK sourced ones I could find, plus a tad thicker as they tend to supply 3mm or 5mm ones.
The threads on the front studs of the 3rd Gen will accommodate this thickness of spacer using original nuts with at least 7 full turns of thread still available, even more on the rear. A margin I'm quite happy with.
Best of all, having purchased them last Monday, they arrived this morning, not bad considering yesterday was a public holiday, all for the princely sum of US$30.99 inc P&P for a set of 4.
All fitted and no more clearance problems, now if the test centre would just answer their phone so I can book my re-test .........
(I would take piccies, but its not really a noticaable difference to the eye)
