Could Anyone Tell Me If It Is Ok To Wash My Engine With My Power Washer And If It Is What I Have To Avoid. I Usually Pay For It Doing After Winter But Saw Someone Doing Theirs At A Car Wash So Wondered If It Was Ok To Do?  Any Advice Is Appreciated, Thanks
Cleaning The Engine
 I have cleaned my engine with the pressure washer several times without causing any problems. I usually do it when it is almost cold. Apply the foam. Let it get to work and rinse off without getting in too close. I try to avoid the alternator, fuse box etc. I wouldn't do it to a petrol though.
 Discalimer: Just because I have got away with it doesn't mean everyone will.It's only a hobby!
 The missus comes in handy, I find.Originally posted by kitesurf_philI have cleaned my engine with the pressure washer several times without causing any problems. I usually do it when it is almost cold. Apply the foam. Let it get to work and rinse off without getting in too close. I try to avoid the alternator, fuse box etc. I wouldn't do it to a petrol though.
 Mr Muscle Orange Action sprayed on and left for a while is pretty good. Good for getting oil spots off the drive too. Don't tell Mrs KS I nick it though.Originally posted by dirtydogprobably pressure washed mine at least 6 times now -- GUNK is the best stuff but I cant find the foam variety any more  It's only a hobby! It's only a hobby!
 Luckily I've got my hands on some truck wash...just add loads of water to it to thin it down and boy does it clear a lot of crap off the vehicle.
 If you have a petrol...then could be a problem!...I have pressured washed a petrol engine down but with the engine running to keep water out.
 Diesel engine should be fine, just have the pressure washer some distance from all the major components.Gaz
 Just fills up you footwells too! Brown carpet mats anyone?Originally posted by TonyNLeaving it parked in muddy water didn't hurt it...........
 So clean water won't.
 Its OK, just removes all you cam belt/oil change and battery info labels! I NEED TO OFFROAD! I NEED TO OFFROAD!
 Take it to a local garage for a good steam clean. They'll do a good job for £20 or so. No oily mess on YOUR drive either!!Originally posted by WADDYThanks For All Your Suggestions, Someone Mentioned Steam Cleaning The Engine Instead Of Pressure Washing It?. I Have One Of Those Hand Held Steam Cleaners Do You Think This Would Do The Job Better Than Washing?. Thanks
 NevillefLast edited by laser_jock@work; 13 May 2005, 13:04._________________
 Nevillef
 Cleaning The Engine
									Cleaning The Engine
								 , I think with a jet washer you might end up forcing water in the air intakes/fitler set-up.
