Diff size
  • Diff size
    Does anyone know what diff size at the back. 8" or 7.5". Thinking of regearing soon or does it say on the diff?
    Derek :
    1990 Hilux Surf SSR Ltd
    8" at the back, 7.5" at the front.
    Roger
      Get the AXLE details from your VIN plate in the engine bay. These are for the rear diff.
      In Surfs the letter at the beginning of the code is normally G indicating an 8" diameter ring gear. F would indicate 7.5", E is 7.1", H is 9" and the list is endless
      The next two digits indicate the gear ratio as follows:
      25 indicates 4.556 gearing
      26 indicates 5.571 gearing
      28 indicates 4.300 gearing
      29 indicates 4.100 gearing
      The last digit indicates the no. of pinions
      2 indicates 2 pinions
      3 indicates 2 pinions with LSDiff
      4 indicates 4 pinions
      5 indicates 4 pinions with LSDiff
      So if your AXLE code reads G254 then you have an 8" ring gear, 4.556 gearing, 4 pinions. I believe the 4.556 gearing suits 31" tyres which did not necessarily come as stock on early 2nd gens, so thats good if you are upgrading to 31's
