I've only had my 1993 3.0TD for a couple of weeks, but as happens every time you buy a car you're unfamiliar with, I notice noises or peculiarities. Nothing has come to anything, but are there any 'stock faults' with this model to be aware of?
Only wee problem I've had is a reluctance for the starter motor to go some mornings (I can hear the solenoid, but nowt happens). After a few tries, it usually starts and fires no problem. Oddly, doesn't seem to be an issue once the car has been run that day. I figure I need to get underneath and check connections to the starter as it seems a little exposed to wet and crud down there.
I'll be having the timing belt changed shortly as I'm not sure whether its been done or not. What is the replacement interval?
Last question question relates to the folding rear seats. There appears to be hinges at the front of the base of the seats, but I'm stumped as to how to lift the bases in order to fold the seats flat. Any clues?
