cold starting missing a beat
  • cold starting missing a beat
    Hi all.... I have noticed on the last few chilly mornings that when the engine starts and which I must say it starts at the first turn of the engine, it has a few misses as if it's not running on all the cylinders, it's only for a very short while and seems ok as soon as you pull away, is this a normal surf thing?
    Try letting the plugs warm up a little longer. They carry on heating up for a while after the lamp goes out on the dash. I wait till I hear 2 'clicks', the second one being quite faint (with the keys left in siren screeming it's hard to hear sometimes) or try switching the ignition on and off a couple of times. If these things dont work, it might be worth getting your glow plugs checked out.
    Pete
      I reckon this is a trait of diesel engines. I have an old 4trak which does the same thing - its a 2.8TDi. What I do, is switch on the ignition and wait for the glow plug light to go off , then switch off and back on again and the glow plug light comes back on - as soon as it goes out, I start the engine and it runs fine.(If its really cold, I do it three times)
      I haven't had a problem with my surf - yet! - but the cold mornings are coming! Bit of a frost this morning.
      Anyway, hope that helps.
      Redneck
        same problem
        I have the same problem, but only fitted new plugs 2000k ago, so i just leave it a few seconds after lamp goes out and all seems fine.
        Steve
        ssrx
        Dave ssrx 3.0td Ltd auto Gen2
          sounds like one of your plugs isnt working
          [size=5][/size]
            jerks
            Thanks for the replies, I will try out the suggestions above and let you know how I get on, a little added question as we are on the diesel thing.
            When driving during the day I don't notice any smoke at all behind me when I accelerate, but at night when I do, I see smoke in the headlights of the car behind, has anyone else seen this while accelerating in the dark and being followed by another vehicle, I don't mean having my foot flat to the floor, just above average acceleration.
              Now that you mention it I see it too ???
              I have been using Redex and thought the smoke had gone as I can hardly see any in the daylight but at night it's like a fog.
              Ian
              One day my paranoia will go away!
                It's a Diesel!
                  Originally posted by rich
                  It's a Diesel!
                  hehe, yeah, expect some, ever watch a tractor pull or truck racing? (before they fitted smoke reducers) a diesel under load will make plenty black smoke.
                  But a clean, well serviced road car should only make a small puff at high revs.
