rear wiper ??
  • rear wiper ??
    just tried my rear wiper for the first time this morning, and i'm a bit puzzled what to do.
    It goes through the motions just like a wiper should, but the blade doesn't seem to contact the window except for a short section of the arc when an inch or so nudges the water a bit!
    Its a 3rd Gen SSR-X and i wondered if anyone else has had this problem. Is there anything i can adjust to make it wipe a bit better?
    ta
    adam
    adam
    "silly keeps you sane"
    ta
    adam
    sounds like the blade/arm is bent. Had this on mine. Touched the lower part of the window but not on the way up, a little bit of a bend here and there and got it working.
    My 4x4
    My choice
    Back off
      thanks....i'll have a closer look at it later on.
      adam
      adam
        adam
        ADAM ive not seen your beast in Altrincham yet mate.
          parked up in broadheath where i work....but it passes through the town centre morning and night.
          perchance were you driving onto deansgate last monday morning about 9.30?
          adam
            Most probably mate! Atlantic st your works mate ??
              close...hanover road.
              adam
