Hello All,
Had a scare tonight on the motorway, The temp guage started to go up so I put the front heater onto hot and then reached behind to do the same to the rear heater. I though this would be a good idea to give the car a much cooling as possible.
When I did put my hand back to the rear heater temp control it was all sopping wet.
Decided to remove the rear heater matrix and found it to be holed on the bottom corner but, I also buggered on of the pipes getting the rubber tube off.
Anyone know were I can get a new rear heater matrix from and if so how much.
I am open to a second hand unit if any of you guys and girls has one laying around.
Give me a call on 07817 252 902 or send email to:
mike.boreham@johnsondiversey.c om
Thanks in advance.
Mike B
Thanks in advance.
Mike B
