I have a new thermostat to fit but after reading Haynes Manual tried to also buy a gasket for the actual housing. Toyota ended up supplying a small rubber ring that came with thermostat anyway. Do I definately need the housing gasket if there is one? and do I need a torque wrench to bolt back together, Haynes recommend 19nm,s the wrench I have does not go that low.
Any comments appreciated.
