Door Lock Barrels
  • Door Lock Barrels
    Hi All
    Can anyone give me a pointer for where to source a set of door lock barrels for my 96, 3rd Gen KZN 185 please. Central locking works but tumblers are broken I think and a drenching in WD40 doesn't help it.
    Also if anyone has part numbers that would be great too.
    Hi m8 try a local breakers pal or eBay might be a good option, if you spray them with wd40 make sure you grease them up after with white grease or any lithium based grease or it will make it worse as the wd40 will clean and wash out any grease already inside The door lock itself might take abit of working and tapping but they should free off if they are stuck
    Good luck
    Go Hard Or Go Home
      I got a couple of locks from eblag and rebuilt my damaged drivers door lock.
      If you're lucky you'll get the right levers in it, if not you can file them to the right shape.
        Thanks for the suggestions guys. I saw some barrel sets on the Roughtrax site but I suspect that they are for gen 2 surfs,
