Hi, I have a 1994 3.0 surf but I'm not 100% convinced that it has the correct dipstick at the moment. Can anybody let me know the measurements of a genuine dipstick for this model? Thanks
Dipstick measurements
Maybe this will help:
http://www.hiluxsurf.co.uk/archive/i...p/t-61824.html
It is for a KZN185, but as a 3 litre, it probably is the same, but don't quote me.
Hmm, Curiouser and curiouser.... Just measured the dipstick on my 1993 KZN130, 3 Litre and this is what I found (using the same calculations as in the previous:
Overall length including ring pull is 665mm
From where the stick sits flush to tip of the stick is 590mm
From where the stick sits flush to full mark is 557mm
From where the stick sits flush to low mark is 578mm
"From where the stick sits flush" I presume to be at the bottom side of the fat washer thing that sits flush when the stick is inserted. I don't know why my figures are different to those others, but if you know your own overall stick measurement you can work it out.
I doubt mine is incorrect. I have had the car for about 12 years without a hassle and have maintained the oil system (and everything else) all that time.Originally posted by Fankiemuzza View PostThanks everyone, that's a great help.
Yorta2, my measurements match yours exactly so hopefully we've both got the correct ones and not both got the same wrong one!
