on the surf i just bought it has a turbo timer which i would like to disconnect how does one go about doing this i cant get used to locking the car walking away and its still running
Its gonna really depend on the type/model of timer and if you can see or find where it is installed.
Not had any experience with them myself but someone supplied this article for my site that may be of some use: http://www.showmesome.info/hilux/wor...turbotimer.htm
Seems like this one is quite simple with just four wires going to the ignition.
Have a look at your ignition wiring and see if you can see extra wires or a unit - if its fused you may even be able to just take out the fuse to disable the timer or perhaps it may even have an on/off switch?
on most turbo timers there is two buttons the one on left to set between 1&3 min and right hand button should be on&off hope this helps if not just disconect live feed from ignition
