Anyone got pic for the EGR mod on a Gen2 2.4, all the links seem to be dead. Just looking for which pipe I need to fold and cable tie.
EGR Mod
Don't have a pic of it as I removed mine when the engine was out. However, there's a pipe at the back of the engine that goes from the area under the turbo and around the block to the other side. I made two blanking plates to cover holes left behind, unplugged the two vsv valves and removed the vacuum pipes altogether.
Come to think of it, there might be a pic of it in my thread about replacing my cylinder head.
I can't put the link up at the minute as I'm at work, lol.
Hope this helps
Update
Hi guys,
Thanks for the advise and pics, it helped a lot.
done the pipe bend and cable as a temp thing... which works, so I blank it off completely next time I have to do some proper work on the engine....
Moving onto the NEW problem I've created... Check the engine section as I need help fast as I'm going to a scrap yard tomorrow where I can help really really cheap surf parts....
