Hi guys,
I have an issue with my radiator empting. It is coming from behind the engine, if you look at the engine head on it is right at the back, in the middle around 20cm or so down. I have a KZN130. I cant see the leak itself so just need a few thoughts on it and what you recommend. I can see a couple of pipes heading that way but cant get to them.
Thanks in advance,
Ed
Thanks in advance,
Ed
