Hey guys, any ideas here would be much appreciated.
My mates 2nd gen has developed a fault with the box. All is fine for the first 5mins driving. Box selects all gears up and down, kick down works right etc etc.
Then after a few mins driving the overdrive refuses to lock in. No fiddling with the button or selector helps till its cooled right down again and you get a few mins of correct function.
So far we have given it a Rodney flush as the oil was stinking, brown and gungy but that has not solved the issue, just given the box a total 12l change of oil.
Research shows this could be down to the ECU showing its age maybe? Or a solenoid sticking? I think he can check the actual overdrive function by unplugging the solenoids and changing manually? Would this then help narrow down where the fault lies?
I am asking for any other ideas or pointers as the next step will be taking it to OVER FAB for a look see and I would like to close down as many options as possible before he has to reach into his pocket.
Many thanks for any ideas or experience.
though you never know.
